Route traffic In Interface
Hello..
I need help..
How do I make 10.116.40.190 IP traffic to go out the ETH5 ?
The rest by the ISP that is in the ETH1
  • assign your MikroTik an IP address in 192.168.25.0/24 on port ether5
  • add a route to 10.116.40.190 via gateway 192.168.25.1
  • add a route in the cisco back to 192.168.1.0/24 via the MikroTik’s address
I am one Bridge in Eth2,Eth3 y Eth4 for LAN (192.168.1.0/24)
1-Should I add the eth5 within the Bridge? Currently it is not
2- This is my commands
/ip address add address=192.168.25.254 interface=ether5 netmask=255.255.255.0 network=192.168.25.0
/ip route add dst-address=10.116.40.190 gateway=192.168.25.1
Ping From Mikrotik to 192.168.25.1 & 10.116.40.190 is OK
but Ping from LAN is error.
What can be ?
  1. no
  2. maybe you have firewall rules in the router that you did not tell us about?
Traceroute from Mikrotik:
Trace to 10.116.40.190 (OK)
ADDRESS LOSS SENT LAST AVG BEST WORST STD-DEV ST..
1 192.168.25.1 0% 21 0.5ms 0.6 0.4 2.2 0.4
6 10.116.40.190 0% 21 28.4ms 28.7 28.1 33.2 1
Traceroute from PC
Trace a 10.116.40.190 (ERROR)
1 5 ms 2 ms 1 ms shaas.loc [192.168.1.1]
2 * * * Tiempo de espera agotado para esta solicitud.
3 * * * Tiempo de espera agotado para esta solicitud.
Trace a 192.168.25.1 (ERROR)
1 2 ms 1 ms 1 ms shaas.loc [192.168.1.1]
Is there any way to detect what is the rule that is blocking?
Thanks!!!..
You may use torch tool to capture traffic
Also you should use ping tool from mk and send ping from local bridge interface.
