Route two networks & VPN
Hi There,
I’ve been trying different configs to consolidate two networks and VPN, so I can access everything when working between the two and remotely. Haven’t had much success setting it and I was wondering if anyone had a simple way with good results:-)
My networks over one router.
Network 1 - 192.168.6.0/24 - Ether 3
Network 2 - 192.168.7.0/24 - Ether 4
VPN - 192.168.10.10 - Remote PPP single IP.
Regards,
Pipa
Hi, what Kind of vpn you configured pptp or l2tp ? Then i can send you the right ip Route configuration .
Gesendet von iPhone mit Tapatalk
Hi There,
The vpn config is “pptp”
Regards,
Pipa
Hi , do. this in your route section , dst address 192.168.6.0/24 gateway vpn Interface and the same to 192.168.7.0/24 and do. a Proxy arp on both interface ether 3 and ether 4 .
Regard
