Route Wireguard traffic through specific WAN interface
We have a multi-WAN setup and want to route all Wireguard traffic through a specific WAN interface, pppoe-vpn, which is assigned a static IP at ISP level. Here’s the network diagram:
And this is the config:
# RouterOS 7.6
# model = RB750Gr3
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add disabled=no interface=ether1 name=pppoe-backup use-peer-dns=yes
add disabled=no interface=ether1 name=pppoe-vpn use-peer-dns=yes
add disabled=no interface=ether1 name=pppoe-wa use-peer-dns=yes
/interface wireguard
add listen-port=54321 mtu=1420 name=wireguard0
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.10.101-192.168.10.254
add address-pool=dhcp interface=bridge lease-time=12h name=dhcp0
/port
set 0 name=serial0
/routing table
add disabled=no fib name=vpn
/ip settings
set rp-filter=loose
add interface=pppoe-vpn list=WAN
/interface wireguard peers
add allowed-address=192.168.9.3/32 comment=mac interface=wireguard0 \
    persistent-keepalive=25s
add address=192.168.10.83/24 comment=defconf interface=bridge network=\
    192.168.10.0
add address=192.168.9.83 comment="wireguard interface local  ip" interface=\
    wireguard0 network=192.168.9.0
/ip cloud
set ddns-update-interval=15m
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.10.93 lease-time=23h59m59s mac-address=yy:yy:yy:yy:yy:yy \
    server=dhcp0 use-src-mac=yes
add address=192.168.10.0/24 comment=defconf dns-server=192.168.10.83 gateway=\
    192.168.10.83 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.10.83 comment=defconf name=router.lan
    established,related,untracked
    invalid
add action=accept chain=input comment="accept wireguard" dst-port=54321 \
    in-interface=pppoe-vpn protocol=udp
    in-interface-list=!LAN
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes hw-offload=yes
    connection-state=invalid
/ip firewall mangle
add action=mark-routing chain=prerouting comment=\
    "mark wireguard connections - prerouting" dst-port=54321 \
    new-routing-mark=vpn passthrough=no protocol=udp
add action=mark-routing chain=output comment=\
    "mark wireguard connections - prerouting" new-routing-mark=vpn \
    passthrough=no protocol=udp src-port=54321
    ipsec-policy=out,none out-interface=pppoe-vpn
    ipsec-policy=out,none out-interface=pppoe-wa
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-wa pref-src="" \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-vpn \
    routing-table=vpn scope=30 suppress-hw-offload=no target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Africa/Johannesburg
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=all filter-ip-protocol=udp filter-port=54321
Disabling these 2 mangle rules…
/ip firewall mangle
…and attempting to connect a peer through the static IP yields the following via the packet sniffer (actual listening port redacted but let’s pretend it’s 54321 as per above config):
The packet is received through the pppoe-vpn interface but is responded to from the pppoe-wa interface - the default interface. As a result, no handshake takes place.
Enabling the 2 mangle rules yields the following result:
The packets are being responded to on the correct interface but
  1. There is a big delay in the response.
  2. The response is not being sent through the same port it was requested from - the peer is connecting from port 24099 but the response is being sent to port 22505.
Some info that may or may not be relevant:
  1. The static IP of interface pppoe-vpn is assigned at ISP level. On the router itself, we get assigned a dynamic NAT’ed (we beg pardon if this isn’t the correct term) IP (10.230.68.216 in this case) and we don’t see the actual static IP anywhere on the router.
  2. When using pppoe-vpn as the default gateway using the default routing table, the handshake takes place without issue.
Please advise, oh wise Ones - what are we doing wrong?
To be clear, is your wireguard instance on the router acting as a server for handshake or is it connecting to something else as a client?
What is the purpose of the wireguard. So far it seems the requirement is for local users to go out a specific WAN but to what for example.
Also you are missing an IP address for wireguard in the config.
The Wireguard instance on the router is indeed acting as a server for handshake (that’s the intention, anyway).
The purpose is for peers to connect to the local network remotely, and access hosts within the local network, for remote work.
Noted and will add an IP address under
/ip addresses
for the Wireguard interface - the plan was to sort that out after establishing a reliable handshake.
Realised an error in the mangle rules -
src-address-type=""
After removing this condition, the packet sniffer now looks like this:
As a result, still no handshake takes place.
Updating the OP with this info as well.
(1) Why isnt the primary WAN pppoe not part of the wan list??
In other words
add interface=pppoe-wa list=WAN
(2) Persistent keep alive for the incoming remote user .3/32 makes no sense. Should be set at the client.
(3) When you construct your IP address say 192.168.9.1/24 this will cause the router to auto generate a routing.
dst-address=192.168.3.0/24 gwy=wireguard0 table=main
This means that when the remote users access the LAN for traffic, the return traffic will be correctly routed through the tunnel that was established over the VPN WAN link.
(4) Where more work would be required is if:
a. you wanted remote users to go out your internet like out pppoe-wa for instance, OR
b. you wanted local user to go out wireguard (lets say if you had another router as a client and there were remote subnets local users needed to reach).
(5) Finally yes disable the mangle rules as their need is not clear yet but may be needed later or some variant of.
Now looking at your current route rules for pppoe, wireguard handshake is not working, maybe due to the that fact that you don’t have the standard route for pppoe-vpn so if you have multiple wans you at least need the standard routing for each WAN, for standard traffic to the router etc.
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-wa pref-src=“”
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-vpn pref-src=
“” routing-table=vpn scope=30 suppress-hw-offload=no target-scope=10
TO:
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-wa table=main
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=pppoe-vpn table=main
In this regard normal traffic will flow and the handshake should work. Note I added a distance of 2, to your vpn network.
This will ensure all users go out the pppoe-wa WAN connection for internet.
OK, have added all pppoe interfaces to WAN list, removed persistent keep alive for peer (it was indeed also set on client), added IP for Wireguard interface (which added a dynamic routing to the main routing table), disabled the mangle rules, and updated the pppoe-vpn route.
Config now looks like:
# RouterOS 7.6
# model = RB750Gr3
/routing table
add interface=pppoe-backup list=WAN
    192.168.10.0
add address=192.168.9.83/24 comment="wireguard interface local  ip" \
    interface=wireguard0 network=192.168.9.0
    invalid
    out-interface-list=WAN
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=pppoe-vpn pref-src=\
    "" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
Packet sniffer shows packet coming in through pppoe-vpn but response still goes out through the default gateway, pppoe-wa:
And no handshake.
Is this masquerade rule correct?
Yes masquerade rule is correct, it was me that erred.
Lets fix this for you.
By the way what is with .83 LOL, its when I graduated University, so its a nice number!
Please add this third route and routing rule…
“” routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=pppoe-vpn table=vpn
/routing rule
add interface=src-address=IPaddress (of pppoe-vpn) action=lookup-only-in-table table=vpn
That should allow the handshake
Problem is that that IP is not static right ???
If not then you will need a script to keep it correct.
Brilliant. Handshake now takes place and client peer can remotely access local network and hosts. Thank you Sagely One, much appreciated.
We preferred 83 over the default 88 because 83 > 88.
Indeed. Have seen script guides floating about - will consult one and implement.
Client peer’s internet is also going out via pppoe-wa. This is what we want, but for the record just wondering what about the setup is allowing this? Since earlier you stated:
a. > you wanted remote users to go out your internet like out pppoe-wa for instance> , OR…
That is handled mostly by firewall rules.
Since yours are terrible and by that I mean loosey goosey, I dont think there will be an issue.
If you had better rule sets, then one would have to consider ensuring that specific traffic was permissible.
The MT OS default construct is to block a few known things but allow everything else all other traffic., known or unknown!
I always recommend moving to the construct of only allowing known things and blocking everything else, known or unknown.
For example.
add chain=forward action=accept in-interface=wg dst-address=local_subnet
add chain=forward action=accept in-interface=wg out-interface-list=WAN
(which can be done by adding wg to LAN interface list, and thus would follow this rule
add chain=forward action=accept in-interface-list=LAN out-interface-list=WAN
If one of your clients was another mT router with subnets, one would have to consider additional routes so the router knows were to send return traffic (coming from internet or local subnet devices).
Understood. Your ways make more sense than those we’re accustomed to so we shall gladly adopt them. We appreciate your guidance.
We recently needed to expose other services on the pppoe-vpn interface e.g. forward port 2222 requests on pppoe-vpn to 192.168.10.14. The requests are sent to 192.168.10.14 successfully but the response gets sent from the default gateway, pppoe-wa, causing the connection to fail. As a temp workaround we created the routing rule
/routing rule
add interface=src-address=192.168.10.14/32 action=lookup-only-in-table table=vpn
but would prefer all traffic to get routed on the WAN interface the request originated from. What’s the best way to achieve this in RoS7.8 (RB5009)?
Well changing requirements mid-stream is not trivial.
In this case, would need to see the complete config again ( minus router serial number, any publicWANIP info, keys etc.).
To ensure LAN server replies to the specific incoming WAN, one must consider mangling and once we start mangling, we have to ensure there is no overlap with routing rules as mangling takes precedence. Thus important perhaps to reconsider a strategy, but seeing the complete config will point us in the right direction of whats optimal.
Gratitude - locating the correct rabbit hole involved less effort.
Hey Anav,
I had the same issue and this worked like a charm. Thank you so much!
Looking at all this now, bashing my head on trying to get this working via mangle made no sense, since the real issue was something else.
well cannot read your mind, if you need an explanation or help.
draw a diagram
describe the wan situation
provide the complete config minus sensitive information
