Connection tracking is off.
RB532 #1
[admin@MikroTik] > interface wireless print
0 X name=“wlan1” mtu=1500 mac-address=00:15:6D:50:0A:88 arp=enabled
disable-running-check=no interface-type=Atheros AR5213
radio-name=“00156D500A88” mode=station ssid=“MikroTik” area=“”
frequency-mode=manual-txpower country=no_country_set antenna-gain=0
frequency=2412 band=2.4ghz-b scan-list=default rate-set=default
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,
54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007
ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default
periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150
wds-ignore-ssid=no update-stats-interval=disabled
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default
disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
compression=no allow-sharedkey=no
1 R name=“wlan2” mtu=1500 mac-address=00:15:6D:51:09:B2 arp=enabled
radio-name=“00156D5109B2” mode=station-wds ssid=“MikroTik” area=“”
frequency=5180 band=5ghz scan-list=default rate-set=configured
54Mbps
basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic
[admin@MikroTik] > interface bridge print
0 R name=“bridge1” mtu=1500 arp=enabled mac-address=00:0C:42:04:EB:06 stp=no priority=32768
ageing-time=5m forward-delay=15s garbage-collection-interval=5s hello-time=2s
max-message-age=20s
RB532 #2
0 X name=“wlan1” mtu=1500 mac-address=00:15:6D:50:0A:8D arp=enabled
radio-name=“00156D500A8D” mode=station ssid=“MikroTik” area=“”
54Mbps
1 R name=“wlan2” mtu=1500 mac-address=00:15:6D:51:09:AA arp=enabled
radio-name=“00156D5109AA” mode=ap-bridge ssid=“MikroTik” area=“”
54Mbps
burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=dynamic
wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150
0 R name=“bridge1” mtu=1500 arp=enabled mac-address=00:0C:42:04:EA:FD stp=no
priority=32768 ageing-time=5m forward-delay=15s garbage-collection-interval=5s
hello-time=2s max-message-age=20s
Only getting 14Mbps tcp one way and 7.7Mbps both ways.
