hi all
I am trying to setup a router with 1 wan (ether1) end 6 Vlan, and i am relly lost now ![]()
All the VLAN need to have internet access and vlan 1 and 3 need to send DHCP.
My setup is a 2011UAS-2HnD setup as Router vith vlan and the rest of my Network is Cisco sw that is why ether 5 is trunk. Cisco is setup with trunk to port 5 with native 999 and all that is woking.
I cant get internet on any of my WLAN
I no there is a lot of post in here and i have try many Things now with out Lock ![]()
Can somone maybe try look at my settings and tell me whar i am doing worng?
Cheers
Jimmy
add name=bridge-vlan1
add name=bridge-vlan2
add name=bridge-vlan3
add name=bridge-vlan4
add name=bridge-vlan5
add name=bridge-vlan10
add name=bridge-vlan999
/interface vlan
add interface=ether2 name=vlan1-ether2 vlan-id=1
add interface=ether5 name=vlan1-ether5 vlan-id=1
add interface=ether5 name=vlan2-ether5 vlan-id=2
add interface=ether3 name=vlan3-ether3 vlan-id=3
add interface=ether5 name=vlan3-ether5 vlan-id=3
add interface=ether5 name=vlan4-ether5 vlan-id=4
add interface=ether5 name=vlan5-ether5 vlan-id=5
add interface=ether5 name=vlan10-ether5 vlan-id=10
add authentication-types=wpa2-psk eap-methods=“” management-protection=
allowed mode=dynamic-keys name=test supplicant-identity=“”
wpa2-pre-shared-key=12345678
allowed mode=dynamic-keys name=test2 supplicant-identity=“”
/interface wireless
set [ find default-name=wlan1 ] disabled=no mode=ap-bridge security-profile=
VMCK ssid=VMCK wireless-protocol=802.11
add disabled=no keepalive-frames=disabled mac-address=D6:CA:6D:0A:55:AB
master-interface=wlan1 multicast-buffering=disabled name=wlan2
security-profile=TTS ssid=TTS wds-cost-range=0 wds-default-cost=0
wps-mode=disabled
/interface vlan
add interface=wlan1 name=vlan1-wlan1 vlan-id=1
add interface=wlan2 name=vlan3-wlan2 vlan-id=3
add name=dhcp-vlan1 ranges=192.168.1.2-192.168.1.199
add name=dhcp-vlan3 ranges=192.168.0.200-192.168.0.254
add address-pool=dhcp-vlan1 disabled=no interface=bridge-vlan1 name=
dhcp-vlan1
add address-pool=dhcp-vlan3 disabled=no interface=bridge-vlan3 name=
dhcp-vlan3
/tool user-manager customer
set admin access=
own-routers,own-users,own-profiles,own-limits,config-payment-gw
add bridge=bridge-vlan1 interface=vlan1-ether2
add bridge=bridge-vlan1 interface=vlan1-ether5
add bridge=bridge-vlan2 interface=vlan2-ether5
add bridge=bridge-vlan3 interface=vlan3-ether5
add bridge=bridge-vlan4 interface=vlan4-ether5
add bridge=bridge-vlan5 interface=vlan5-ether5
add bridge=bridge-vlan10 interface=vlan10-ether5
add address=192.168.1.1 interface=bridge-vlan1 network=255.255.255.0
add address=192.168.0.1 interface=bridge-vlan3 network=255.255.255.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.0.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.0.1
add address=192.168.1.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.1.1
set servers=8.8.8.8,8.8.4.4
add action=accept chain=forward disabled=yes in-interface=bridge-vlan1
out-interface=ether1
add action=accept chain=forward disabled=yes in-interface=bridge-vlan3
add action=accept chain=forward disabled=yes in-interface=bridge-vlan2
add action=accept chain=forward disabled=yes in-interface=bridge-vlan4
add action=accept chain=forward disabled=yes in-interface=bridge-vlan5
add action=drop chain=forward disabled=yes
add distance=1 gateway=ether1
/system clock
set time-zone-name=Europe/Copenhagen
/system identity
set name=“VMCK Marster Router”
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set bridge-vlan1 disabled=yes display-time=5s
set bridge-vlan2 disabled=yes display-time=5s
set bridge-vlan3 disabled=yes display-time=5s
set bridge-vlan4 disabled=yes display-time=5s
set bridge-vlan5 disabled=yes display-time=5s
set bridge-vlan10 disabled=yes display-time=5s
set bridge-vlan999 disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set sfp1 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
set ether6 disabled=yes display-time=5s
set ether7 disabled=yes display-time=5s
set ether8 disabled=yes display-time=5s
set ether9 disabled=yes display-time=5s
set ether10 disabled=yes display-time=5s
set wlan2 disabled=yes display-time=5s
set vlan1-wlan1 disabled=yes display-time=5s
set vlan3-wlan2 disabled=yes display-time=5s
set vlan1-ether5 disabled=yes display-time=5s
set vlan2-ether5 disabled=yes display-time=5s
set vlan3-ether5 disabled=yes display-time=5s
set vlan4-ether5 disabled=yes display-time=5s
set vlan5-ether5 disabled=yes display-time=5s
set vlan10-ether5 disabled=yes display-time=5s
set vlan1-ether2 disabled=yes display-time=5s
set vlan3-ether3 disabled=yes display-time=5s
/system routerboard settings
set silent-boot=no
/tool user-manager database
set db-path=user-manager
