I would like to have my Multi-radio RouterBoards (5 radios) run on Batteries that are continuously charged. I have 2 kinds of POE injectors for my units, ones that have two piece POE injectors and some that are a one peice POE injector. A while ago MikroTik support told me that the two peice POE injector did not put out enough power in order to power the multiport routerboards and that the one peice routerboards should be used instead. My questions are:
If I fed 48v into the injector of the 2 peice POE injector would the multipoint boards run reliably at 350’ of ethernet? I.e. Is the power problem in the brick or the injector in the POE injector?
If I fed 48v directly into the blues and browns of the ethernet cable what would happen to the routerboard?
If I have to use the one peice POE injector for the multi-radio routerboards, what would be the best approach to have them run on 48v or 24v powersupplies?
Thanks,
Ken
