Hi all,
i am seeking a 4 indipendet gigaEthernet port router.
Can anyone help me ?
I worked with a R2011, but this is only two ports.
thank you.
Mauro
Hi all,
thank you.
Mauro
See the block diagrams on the product pages. CCRs have independent ports. But maybe you don’t need exactly that, you should describe your situation to get better advice…
Hi.
The new RB750Gr3 ? If I read correctly, it has no switch, all ports connected directly to CPU…
Best regards: CsXen
Thank you.
I need 4 indipendent port with 4 ip address because i need to perform Policy Based Routing.
Thank you.
Mauro
And your ISP gives you gigabit on each link?
As the data pass through the router, you need at least 2 times more capacity of such ports, otherwise what would you do with the traffic?
No but my ISP give me more than 100Mb on each link.
Thank you.
Mauro
You need processing capacity. Look at ccr at least.
Peli: RB750Gr3 has either one or two internal Gigabit links to the built in switch (that has 5 external ports). Unless you need more than 1Gbps combined up+down, a single 1Gbps internal should be enough.
