router 433 doesn't boot
*dear friends
\i have router 433
i don’t know why it doesn’t open with win box
i get no replay ???!!
and when i start it i don’t hear beeb sound when it boot
blue led work ok
the LED not all work
LED505 doesn’t work
why does that happend
can it be fixed ???
User Null modem cable and check the console output from the router,
http://wiki.mikrotik.com/wiki/First_time_startup
If you have problems post the output from the console here.
me too.
also I try press key within 2s but no any other result.
below is mine in console windows.
RouterBOOT booter 2.20
RouterBoard 433UAH
CPU frequency: 680 MHz
Memory size: 128 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Kernel panic - not syncing: No init found. Try passing init= option to kernel.
I solved my problem.
the keypoint is that 433 use a pushbutton to select boot way.
press that button with power-on then I can see I want to see.
this is the important information I want to share.
then it is OK to follow netinstall wiki.
Hi
I have 433ah
when i connect the power LED 501-504 is burn and blue and green LED on too.
board did`t startup.
in hyper terminal did not write anything
Sorry, my English is bad
Hi, I have the same problem
RouterBOOT booter 2.6
RouterBoard 532
Authorization: Passed
CPU frequency: 266 MHz
Memory size: 32 MB
It’s not clear how to solve the problem, I need help, please
Make fresh installation with Netinstall, it seems there is problem with FS on flash and I suppose there is risk that you have lost license key.
