Hello, i’m running hap ac on default configuration. I added l2tp server and a different address range for vpn. I can access devices on the network over vpn but not the router. What else i need to do?
I added the l2tp as such:
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-256,aes-192,aes-128 lifebytes=1
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1 pfs-group=modp2048
add name=vpn ranges=192.168.89.2-192.168.89.255
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/interface l2tp-server server
set enabled=yes use-ipsec=yes ipsec-secret=test
add action=accept chain=input comment=“allow ESP” protocol=ipsec-esp
add action=accept chain=input comment=“allow IPsec NAT” dst-port=4500 protocol=udp
add action=accept chain=input comment=“allow IKE” dst-port=500 protocol=udp
add action=accept chain=input comment=“allow l2tp” dst-port=1701 protocol=udp
add action=accept chain=input comment=“allow pptp” dst-port=1723 protocol=tcp
add action=masquerade chain=srcnat comment=“masq. vpn traffic” src-address=192.168.89.0/24
/ppp secret
add name=vpn password=test profile=default-encryption remote-address=192.168.89.254
add name=remote password=test profile=default-encryption remote-address=192.168.89.253
