Hi all,
My scenario is the following:
<< Internet >>
| wan
| | 172.16.2.0/24 via 172.16.1.2
| MIKROTIK | 172.16.3.0/24 via 172.16.1.2
| lan 172.16.1.1/24
| wan 172.16.1.2/24
| Debian OS | 172.16.3.0/24 via 172.16.2.2
| Server | def gw 172.16.1.1
| lan 172.16.2.1/24
| wan 172.16.2.2/24
| 3com router | def gw 172.16.2.1
| lan 172.16.3.1/24
| 172.16.3.x/24 def gw 172.16.3.1
| Clients |
# oct/31/2008 19:06:21 by RouterOS 3.15
add comment="Default Gateway" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=x.x.x.x scope=30 target-scope=10
add comment="" disabled=no distance=1 dst-address=172.16.2.0/24 gateway=172.16.1.2 scope=30 target-scope=10
add comment="" disabled=no distance=1 dst-address=172.16.3.0/24 gateway=172.16.2.2 scope=30 target-scope=30
set 0 arp=enabled auto-negotiation=yes cable-settings=default comment="" disable-running-check=yes disabled=no full-duplex=yes mac-address=00:0D:88:68:8A:98 mtu=1500 name=wan speed=100Mbps
set 1 arp=enabled auto-negotiation=yes cable-settings=default comment="" disable-running-check=yes disabled=no full-duplex=yes mac-address=00:0D:88:68:8A:99 mtu=1500 name=lan speed=100Mbps
add address=x.x.x.x/28 broadcast=x.x.x.x comment="" disabled=no interface=wan network=x.x.x.x
add address=172.16.1.1/24 broadcast=172.16.1.255 comment="" disabled=no interface=lan network=172.16.1.0
On Mikrotik I can ping Debian (no firewall, no nat), but can’t ping the router neither the clients. On Debian I can ping everybody. Why? Is there a way to make Mikrotik reach everybody?
Thanks in advance,
Ben
