Router Board 750 use as a vlan switch.
I have bridged all the ports using the bridge tab
i am trying to pull vlan trunks off of port 1 and push vlan number 50 onto ports 2-4
any idea how i would go about doing this or can u point me in the right direction?
post ur config…
Not sure if this is what your looking for.
add bridge=bridge1 comment=“” disabled=no edge=auto external-fdb=auto horizon=none interface=ether1 path-cost=10 point-to-point=auto priority=0x80
add bridge=bridge1 comment=“” disabled=no edge=auto external-fdb=auto horizon=none interface=ether2 path-cost=10 point-to-point=auto priority=0x80
add bridge=bridge1 comment=“” disabled=no edge=auto external-fdb=auto horizon=none interface=ether3 path-cost=10 point-to-point=auto priority=0x80
add bridge=bridge1 comment=“” disabled=no edge=auto external-fdb=auto horizon=none interface=ether5 path-cost=10 point-to-point=auto priority=0x80
add bridge=bridge1 comment=“” disabled=no edge=auto external-fdb=auto horizon=none interface=ether4 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set (unknown) vlan-header=leave-as-is vlan-mode=fallback
These are the only non-factory settings I have besides the Address of the machine and routing to get access to it.
