Router-board continues reloading
Hi All
i have RouterBoard which is constantly not booting till the end i.e. it boots > beeps > couple of seconds > reboot again > and repeat endless.
what can i do how can i correct/repair this device.
Model: RB911
laptop MacBook Pro M1
WinBox installed
any help please
You will most likely have to netinstall the device. https://help.mikrotik.com/docs/display/ROS/Netinstall
Mind that it’s a fragile process and you really have to follow all recomendations from the article.
I’m not sure if it’s possible to do it using a macOS device, windows and linux work for sure …
+1 for netinstall, make sure you dont have any virtual adapters enabled on your pc as things like virtual switchs for hypervisors can prevent the layer 2 from forwarding correctly
