i need one mikrotik router board, with at least 2 ethernet interface and one memory card port.
which device you offer me ?
i found RB433UAH, but it have mini pci slots that i have no need them…
thx.
thx.
450G has 5 gigabit ethernet ports and microSD slot: http://routerboard.com/RB450G
hi, thx for you answer, but i can’t found memory slot on this board :
Slot is on other side, you can see that in User Guide : rb450GugA.pdf http://routerboard.com/RB450G
thx, i purchased one rb450G, i see that slot.
how i can attach/plug memory card into it ?
i have attached memory card into router board. but it can’t detect it, how i can solve this problem ?
and which memory cards can detect on this router board ?
plug microSD card into that slot. in RouterOS v5.5 you will see the card in menu “System → Stores → Disks”
hi, i have one 16GB micro toshiba memory card, but when i pluged it into memory slot, nothing happend…
and on disks sumenu, i can’t see that… just i have system with 520.1MB disk space…
is it need special partition table ?
try a different microSD, maybe this one isn’t supported
thx.
is it possible to make board detect this memory card ?
no, if the card is not supported, the only choice is to find a different card, and use this card elsewhere.
aha, ok ![]()
thx.
no news ?
News on what?
about new router boards, with higher cpu rate than 1000mhz…
