Hi,Normis
I noticed that RouterBoard working tempreture is -20 +70 C, Is there any routerboard working tempreture at -40, +70, or -30, +60 should be fine.
Please advise
Dudley
Beijing Mesh Communication Tech Co.
Hi,Normis
Please advise
Dudley
That is the startup temperature. Once the device has booted, it heats itself, so ambient temperature can go below -20C
for example, we have tested that RB800 will continue to work even at -75C ambient temperature. RB800 is also the most durable of our products, since it’s startup temperature is also good -50C.
we tested that RB433AH recently in a chamber, the result was poor,only around -15C, the board stop working, is that normal? or just one bad board, or some other reason, I thought that was close to the specification, and thought the borad may need wide working tempreture range.
Dudley
our own RB433AH test in our temperature chamber showed -30C to +60C
make sure there was no other reason for malfunction.
Like I said, if you want the best, choose RB800 for extreme temperatures.
