Hello, I have just gotten my first mikrotik, an RB2011.
Edit for cleanup: Did some stuff, messed it up, Netinstalled it successfully, but now I cant get to the webfig page to actually set it up, wat do?
Edit2: All Fixed up thanks to Dark and SOB’s simple but effective suggestions, not sure how to mark the topic resolved, if a mod happens by and could do that would be awesome, and again, Thanks Everyone.
Netinstalling would put you into IP addressed with interface = 0.0.0.0
Download Winbox
Connect LAN wire in Eth3 port
Connect to Router using its MAC in the neighbour’s tab
IP > Addresses > Assign a manual ip in the first field like 192.168.1.1/24 and select the ethernet port you are connected to currently ( For here it Eth3)
Now open you pc’s network settings Give it network address > 192.168.1.2 Subnet : 255.255.255.0 Gateway : 192.168.1.1
DNS : 8.8.8.8 and 8.8.4.4
Now try opening 192.168.1.1 .. It will open for sure
