I set up my Mikrotik hap lite a few months ago and I’m quite happy with it - except for one thing.
I’m using the device as a home-router with PPPOE. The clients can access the internet without any problem but the router itself isn’t able to connect to the internet until
I disable the “drop all” rules. So I believe I have a mistake in my firewall config.
Here is my current config (ROS 6.34.6 (bugfix)):
Thanks for your quick answers! The DNS-Servers are set correctly (to OpenDNS) and I also added the new NAT-rule but it still doesn’t work.
If I disable the marked firewall rule, both ping and DNS works:
The screenshot of your rules doesn’t show enough information.
Some columns such as “connection-state” are not shown by default, and the default firewall rule set uses these fields.
Instead of posting a screenshot, open a terminal window and issue the command:
/ip firewall filter export compact
Copy and paste the results (and feel free to redact the public IP addresses that may appear with x.x.x.x)
