Yesterday I got my router working with KPN fiber optics directly on the Mikrotik pppoe-client. I however then locked myself out of my router by removing a wrong line. That made me go back to factor settings but I can no longer get my Internet back online. Config is below and the following messages are displayed:
- dhcp-client keep searching
2 pppoe-client say (blue marked text) not ready or no interface when i run /export
Any thoughts? I am in the woods and can no longer see the trees ![]()
add admin-mac=*** auto-mac=no comment=defconf name=bridge
set [ find default-name=sfp-sfpplus1 ] arp=proxy-arp
/interface vlan
add interface=sfp-sfpplus1 name=vlan1.6 vlan-id=6
/interface pppoe-client
add add-default-route=yes allow=pap disabled=no interface=vlan1.6 keepalive-timeout=20 max-mru=1500 max-mtu=1500 name=pppoe-client user=kpn
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge interface=ether1
add bridge=bridge comment=defconf disabled=yes interface=sfp-sfpplus1
add interface=sfp-sfpplus1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf interface=sfp-sfpplus1
/ip dhcp-server lease
add address=192.168.88.254 mac-address=48:22:54:E4:15:92 server=defconf
add address=192.168.88.253 mac-address=48:22:54:E4:13:BC server=defconf
add address=192.168.88.248 client-id=1:90:9:d0:5:a:7d mac-address=90:09:D0:05:0A:7D server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
# no interface
add action=accept chain=input in-interface=*C protocol=icmp
add action=accept chain=input connection-state=established,related
# no interface
add action=drop chain=input in-interface=*C
# no interface
add action=masquerade chain=srcnat out-interface=*C
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system identity
set name=Maarten
/system logging
add topics=dhcp
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
