I am using Mikrotik Rb4011igs+RM. Currently the router is connected to the ONT device provided by the ISP through ethernet 1. From port 2 to 10, i have connected them to TV PC gaming consoles and so on. I want to switch the connection from the ethernet 1 to the SPF+ port. How do i shift the configuration from ethernet 1 to SPF+.
Of course it depends on your current configuration, post it for review, instructions here:
Loosely, a normal setup is as follows:
ether1 categorised as WAN
all other ethernet ports assembled into a bridge
bridge categorised as LAN
SFP might be "loose" or part of the bridge as well.
So basically you need to make sure that the SFP is "self-standing" (taking it out of the bridge if it is in it), categorise it as WAN, assign to it an IP address (or have a DHCP client run on it) make sure it has a link to the ISP router and that the default 0.0.0.0/0 route is going now through it.
BUT this is true only if you are using the default firewall, if there are changes in filter rules or NAT you might need to adapt them to the new configuration.
