Hello
I am woundering what SACFsd mean in mikrotik connections table and why say time wait. And how to fix this that will work.
I have insert image below for easy understunding.
Hello
The S-seen reply means that “seen new connection is replied by your device” , A-assured means “the connection is trusted” , C-confirmed means “connection is confirmed by your device or firewall” ,
d-dst-nat , F- i think this is FIN i mean no more data from sender it seen after a connection is closed.
I don’t sure about the “s” flag there but if you check your log or sniff your connection on wireshark server, I think you can find the exact meaning.
Best regards,
Small s is “srcnat”
If you hover your mouse over the SACs, it will show you what each one means.
Tnx guys, but i am woundering what mean “time wait” under TCP State.
Does this mean that comands isn’t execute or is anything wrong with settings.
TIME-WAIT is one of the states through which the TCP protocol state machine models its connections
This is a reasonable explanation of it: https://community.apigee.com/articles/7970/tcp-states-explained.html
F=Fasttracked
s=srcnat
