Hi
I have 4 bgp peers (cogent and hurricane electric inclusive), and since I moved to ROS7, I have random crashes, rebooted by the watchdog timer or by a kernel failure.
see below the logs of one of the crashes
Have any of you experienced this in the ros7? what would cause such behavior? rogue/conflicting updates from the uplink suppliers?
In the meantime Ive disabled cogent as when one of the crashes happened, we saw the connection going down on another country we have cogent, and has been stable since then.
Ive opened a support ticket with the autosupout file, but no reply yet.
Hola, tengo un RB1100AHx4, después de actualizar a la versión 7.16 la tabla de ruteo empieza a duplicarse cada vez que las sesiones BGP se reconectan.
Si la sesión se desconecta, las rutas quedan activas. Bajé a la versión 7.15.3 que no presenta ese problema.
Mikrotik Moderator notes - Prior to allowing this post , I converted this post to English using Google translate.
Below is the users post translated to English:
Hello, I have an RB1100AHx4, after updating to version 7.16 the routing table starts to duplicate every time the BGP sessions are reconnected.
If the session is disconnected, the routes remain active. I downgraded to version 7.15.3 which does not have that problem.
