Thanks for the advice, so there is below the configuration.
# may/21/2025 10:14:49 by RouterOS 6.49.15
# software id = Y952-X3FU
# model = 2011UiAS
# serial number =
/interface pptp-client
add connect-to=grupolink.dyndns.org disabled=no name="" \
password= user=
add fast-forward=no name="BD - Rede Local"
set [ find default-name=ether1 ] name="Eth1 - VivoDHCP" speed=100Mbps
set [ find default-name=ether2 ] name="Eth2 - VivoPPPoe" speed=100Mbps
set [ find default-name=ether3 ] name="Eth3 - Rede Local" speed=100Mbps
set [ find default-name=ether4 ] name="Eth4 - Interliga\E7\E3o G4" speed=\
100Mbps
set [ find default-name=ether5 ] name="Eth5 - NetVirtua" speed=10Mbps
set [ find default-name=ether6 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=\
Eth6-Vivo-2
set [ find default-name=ether7 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=Eth7
set [ find default-name=ether8 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=Eth8
set [ find default-name=ether9 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=Eth9
set [ find default-name=ether10 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=Eth10
set [ find default-name=sfp1 ] name=Fibra
/interface pppoe-client
add disabled=no interface=Eth10 name="PPPoE - Vivo" password= user=\
add name=Links
/ip firewall layer7-protocol
add name=Whatsapp regexp=whatsapp
add comment=Bloqueio name=Bloqueio regexp="^.+(clickjogos|jogos360|netflix|str\
eaming|xbox|nintendo|games|jogos|disney|bets|bet|apostas|apostasnacional|b\
et365|blaze|paramount).*\$"
add comment="Bloqueio Pornografia" name="Bloqueio Pornografia" regexp="^.+(xvi\
de|xvideos|redtube|porno|porn|sexo|pornocarioca|xhamster|xham|xxx).*\$"
add name=VPN ranges=10.0.1.10-10.0.1.254
add name="Rede Local" ranges=10.0.0.50-10.0.0.254
add address-pool="Rede Local" disabled=no interface="BD - Rede Local" \
lease-time=1d name="DHCP Rede local"
/ppp profile
add local-address=10.0.1.1 name=VPN remote-address=VPN
/queue type
set 0 kind=none
set 1 kind=none
set 2 kind=none
set 3 kind=none
set 4 kind=none
set 5 kind=none
set 6 kind=none
set 8 kind=none
set 9 kind=none
add bridge="BD - Rede Local" hw=no interface="Eth3 - Rede Local"
add bridge="BD - Rede Local" hw=no interface="Eth4 - Interliga\E7\E3o G4"
/interface l2tp-server server
set authentication=chap,mschap1,mschap2 use-ipsec=required
add interface="Eth5 - NetVirtua" list=Links
add interface="PPPoE - Vivo" list=Links
add interface="Eth2 - VivoPPPoe" list=Links
add interface=Eth6-Vivo-2 list=Links
add interface="PPTP-Grupo Link" list=Links
add interface="Eth1 - VivoDHCP" list=Links
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=VPN enabled=yes
add address=10.0.0.1/24 interface="BD - Rede Local" network=10.0.0.0
/ip arp
add address=10.0.0.116 interface="BD - Rede Local" mac-address=\
/ip cloud
set ddns-enabled=yes update-time=no
/ip dhcp-client
add add-default-route=no disabled=no interface="Eth2 - VivoPPPoe" \
use-peer-dns=no use-peer-ntp=no
add disabled=no interface="Eth5 - NetVirtua" use-peer-dns=no use-peer-ntp=no
add add-default-route=no disabled=no interface="BD - Rede Local" \
add add-default-route=no disabled=no interface=Eth6-Vivo-2 use-peer-dns=no \
use-peer-ntp=no
add add-default-route=no disabled=no interface="Eth1 - VivoDHCP" \
/ip dhcp-server lease
add address=10.0.0.0/24 dns-server=10.0.0.5,10.0.0.11 domain= \
gateway=10.0.0.1 netmask=24 ntp-server=200.160.0.8,200.189.40.8
set allow-remote-requests=yes servers=\
8.8.8.8,8.8.4.4
/ip dns static
add address= name=
/ip firewall address-list
add address=10.0.0.0/24 list="Redes Conhecidas"
add address=10.0.0.240 list="Maquinas liberadas total"
add address=10.0.0.72 list="Maquinas liberadas total"
add address=20.72.0.0/15 list=WindowsUpdate
add address=52.140.118.28 list=WindowsUpdate
add address=52.165.164.173 list=WindowsUpdate
add address=52.137.106.217 list=WindowsUpdate
add address=52.252.198.189 list=WindowsUpdate
add action=drop chain=forward layer7-protocol=Whatsapp src-address-list=\
"Maquinas Bloqueadas Whatsapp"
add action=drop chain=output layer7-protocol=Whatsapp src-address-list=\
add action=drop chain=forward comment=BloqueioPorIPTEMP disabled=yes \
protocol=tcp src-address=143.105.25.131
add action=drop chain=forward comment=BloqueioPorIP disabled=yes protocol=tcp \
src-address=47.238.192.255
src-address=69.55.54.0/24
src-address=138.124.60.132
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark \
dst-address-list="!Redes Conhecidas" in-interface="BD - Rede Local" \
new-connection-mark=NET passthrough=yes src-address-list=NET
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=\
yes in-interface="PPPoE - Vivo" new-connection-mark=Vivo passthrough=yes
in-interface="Eth5 - NetVirtua" new-connection-mark=NET passthrough=yes
in-interface="Eth2 - VivoPPPoe" new-connection-mark=Vivo passthrough=yes
in-interface=Eth6-Vivo-2 new-connection-mark=Teste passthrough=yes
in-interface="Eth1 - VivoDHCP" new-connection-mark=Teste passthrough=yes
add action=mark-routing chain=prerouting connection-mark=Vivo in-interface=\
"BD - Rede Local" new-routing-mark=Vivo passthrough=yes
add action=mark-routing chain=prerouting connection-mark=NET in-interface=\
"BD - Rede Local" new-routing-mark=NET passthrough=yes
add action=mark-routing chain=output connection-mark=Vivo dst-address-list=\
"!Redes Conhecidas" new-routing-mark=Vivo passthrough=yes
add action=mark-routing chain=output connection-mark=NET dst-address-list=\
"!Redes Conhecidas" new-routing-mark=NET passthrough=yes
add action=accept chain=dstnat in-interface-list=Links protocol=gre
add action=accept chain=dstnat dst-port=1723 in-interface-list=Links \
protocol=tcp
add action=accept chain=dstnat dst-port=8291 in-interface-list=Links \
protocol=tcp
add action=masquerade chain=srcnat dst-port=993 out-interface-list=Links \
protocol=tcp
add action=masquerade chain=srcnat dst-port=5938 out-interface-list=Links \
protocol=tcp
add action=masquerade chain=srcnat dst-port=995 out-interface-list=Links \
protocol=tcp
add action=masquerade chain=srcnat dst-port=587 out-interface-list=Links \
protocol=tcp
add action=masquerade chain=srcnat dst-port=143 out-interface-list=Links \
protocol=tcp
add action=masquerade chain=srcnat dst-port=110 out-interface-list=Links \
protocol=tcp
add action=masquerade chain=srcnat out-interface-list=Links src-address-list=\
"!Maquinas Bloqueadas"
add action=accept chain=dstnat dst-port=3389 protocol=tcp
add action=dst-nat chain=dstnat dst-port=1883 protocol=tcp to-addresses=\
10.0.0.240 to-ports=1883
/ip firewall service-port
set sip sip-direct-media=no sip-timeout=0s
/ip proxy access
add action=deny
add disabled=yes distance=1 gateway="Eth2 - VivoPPPoe" routing-mark=Vivo
add disabled=yes distance=1 gateway=201.6.247.1 routing-mark=NET
add disabled=yes distance=1 gateway=Eth6-Vivo-2 routing-mark=Vivo2
add distance=1 gateway="Eth1 - VivoDHCP" routing-mark=VivoDHCP
add disabled=yes distance=3 gateway=201.6.247.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes port=8778
set api-ssl disabled=yes
/ip socks
set port=4153
/ip socks access
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/ipv6 dhcp-client
add interface="BD - Rede Local" request=address use-peer-dns=no
/ipv6 nd
set [ find default=yes ] advertise-dns=no
/lcd
set backlight-timeout=never
/lcd interface
set Fibra disabled=yes
set "Eth1 - VivoDHCP" disabled=yes
set "Eth3 - Rede Local" disabled=yes
set "Eth4 - Interliga\E7\E3o G4" disabled=yes
set "Eth5 - NetVirtua" disabled=yes
set Eth7 disabled=yes
set Eth8 disabled=yes
set Eth9 disabled=yes
set Eth10 disabled=yes
/lcd interface pages
set 0 interfaces="Eth2 - VivoPPPoe,Eth6-Vivo-2"
/ppp secret
/system clock
set time-zone-name=America/Sao_Paulo
/system identity
set name=AEPH
/system logging
add disabled=yes topics=dhcp
add topics=e-mail
/system ntp client
set enabled=yes primary-ntp=200.160.0.8 secondary-ntp=200.189.40.8
/system scheduler
add interval=5m name="update no-ip" on-event=\
"/system script run update-noip\r\
\n" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=jul/25/2024 start-time=16:18:04
/system script
add dont-require-permissions=no name=NO-IP owner= policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
global noipuser \"\"\r\
\n:global noippass \"\"\r\
\n:global noiphost \"\"\r\
\n:global inetinterface \"ether1\"\r\
\n\r\
\n:global previousIP\r\
\n\r\
\n:global currentIP [/ip address get [find interface=\$inetinterface] addr\
ess]\r\
\n\r\
\n:if (\$currentIP != \$previousIP) do={\r\
\n :log info \"No-IP: Sending UPDATE!\"\r\
\n :global str \"/nic/update\?hostname=\$noiphost&myip=\$currentIP\"\r\
\n /tool fetch address=dynupdate.no-ip.com src-path=\$str mode=https us\
er=\$noipuser password=\$noippass dst-path=\"/noip.html\"\r\
\n :delay 1\r\
\n :global previousIP \$currentIP\r\
\n :log info \"No-IP: Host \$noiphost updated on No-IP with IP \$curren\
tIP\"\r\
\n} else={\r\
\n :log info \"No-IP: No update necessary\"\r\
\n}\r\
\n"
/tool e-mail
set address=127.0.0.1 from=""
/tool graphing interface
add
/tool netwatch
