Router firewalling and https problem
I am trying to find a solution with this configuration which for some reason don’t work properly with some https sites like mail.google.com and with some banks as well
here is the firewall configuration
add action=accept chain=input comment=“Accept established connections”
connection-state=established disabled=no
add action=accept chain=input comment=“Accept related connections”
connection-state=related disabled=no
add action=drop chain=input comment=“Drop invalid connections”
connection-state=invalid disabled=no
add action=accept chain=input comment=UDP disabled=no protocol=udp
add action=accept chain=input comment=“Allow specific ports only” disabled=no
dst-port=8291,1723,3333,3334,8080,443 protocol=tcp
add action=accept chain=input comment=“Allow limited pings” disabled=no
limit=50/5s,2 protocol=icmp
add action=drop chain=input comment=“Drop excess pings” disabled=no protocol=
icmp
add action=add-src-to-address-list address-list=blocked-addr
address-list-timeout=1d48s chain=forward comment=“DoS attack Prevention”
connection-limit=100,32 disabled=no protocol=tcp
add action=tarpit chain=input connection-limit=3,32 disabled=no protocol=tcp
src-address-list=blocked-addr
add action=drop chain=input comment=“Block all other incoming ports”
any suggestions ?
Are these all your rules?
You posted only your input chain, no forward so no clue why websites do not work.
Tnx Rudios for reply,
you mean do add only this one?
/ ip firewall filter
add chain=forward in-interface=Local out-interface=Local action=accept comment=“allow traffic”
No not really. I was surprised to see no forward chain. If your forward chain. indeed is empty, it makes no sense that some websites don’t work. Maybe you can post your complete config for us to judge.
this is the complete firewall filter rules except if you need to post and nat and mangle rules as well.
