Router for FTTH autorized with PPPOE and using VLAN
Dear All
I`m looking for the router, which will be able to manage FTTH connection from the Orange ISP.
Orange using pppoe authorization and using vlan 35
Actual speed offered by the Orange ISP is 600/60 Mbit.
In the future maybe more.
I tested CCR1016-12G and this device is able to manage this connection, however this devices is to expensive for private use.
On the RB951G-2HnD there was a problem to handle more then 200 Mbits.
Is there anyone who has some expirience with this French ISP ?
Look at RB850Gx2, RB1100AHx2 or CCR1009-8G-1S-PC
RB850Gx2 is not OS6 capable and also cannot handle more than 200Mbps.
I would suggest you check your facts
  1. you can run RouterOS 6.x on an RB850Gx2
  2. see http://routerboard.com/RB850Gx2 for performance specs
You mean, we can do OSPF + MPLS on a 850Gx2 also ?
Can it handle per port 300-400Mbps even ?
Clearly you need an understanding of how before you do, but yes.
Wow, you are making me happy!
but I saw in router board website, it shows RouterOS5 compatible.
I think, MPLS OSPF only there in Router OS Level 6 license.
The performance specs clearly states that it can handle more than 300-400Mbps, so yes in answer to that - but you can read that for yourself on the link provided. Also all RouterBOARDs run RouterOS and RouterOS supports OSPF and MPLS, so it’s yes to that question as well.
Superb!!!
And if I get a 3011, then can it handle more than 850Gx2, as it has 1G RAM ?
So, get 3011 or 850Gx2 ?
You can make you own conclusion from the following 2 pages of specifications.
http://routerboard.com/RB3011UiAS-RM
Have you looked at the mikrotik/routerboard website at all? All of the specifications are on there. The amount of memory does not equate to speed/throughput
I had checked it since weeks.
Just wanted to get real life review of it.
The throughput you get through each unit depends highly on your rules on firewall/nat etc. If you’ve limited firewall and make use of fastpath then should get throughput close to specified figures.
VPNS (with encryption) and lots of firewall rules all act to reduce your throughput.
Yes, I know!
We will only be using as MPLS ring as a POP NAS>.
