router hangs on log in
My own problem right now is that i cannot log in with the usernames on my winbox.
it will bring hotspot fine but immediately i put in a username or password, it will not log in and the system will hang.
i will have to restart the system over again to be able to use it. the config is ok but i dont understand why it it so.
if i disable the hotspot. the systems will browse normally but as soon as i create hotspot and put in a username and password, the router will hang and i will have to restart. what can i do.
Wale from Nigeria
maybe the hotspot use the ip of your router
try to great the hotsopt and login to router through MAC not ip
