I would like to set up netwatch to email me when a device goes down every 30 minutes. I would like to include in the subject the router identity so I can easily determine which router is sending me the email. Can this be done?
Also, I would like netwatch to email me when the device is back up, but only once, and not every 30 minutes. Can this be done?
Thanks!
I use the system identity name for my voltage reports because I have a few that monitor solar power systems. This is what I use. Maybe it will help you.
:local thisbox [/system identity get name]
:local thisdate [/system clock get date]
:local thishour
:local emessage "Daily voltage report for $thisbox on $thisdate\n\n"
I’m not sure. Is there a constant variable for the system identity that I can just plug in? I see what you are doing.
Here is my little script:
/tool netwatch
add disabled=no down-script=“/tool e-mail send to=tony@xxx.com subject
="Host down!" body="The host is down!"” host=10.0.1.2
interval=30m timeout=5s up-script=“/tool e-mail send to=tony@xxx.co
m subject="Host up!" body="The host is up!"”
I want to add the system identity to the subject for identity purposes.
Thanks.
I did not try this with netwatch, but it works in other scripts.
/tool netwatch
add disabled=no down-script=":local thisBox [/system identity get name];/tool e-mail send to=tony@xxx.com subject\
=\"Host $thisBox down!\" body=\"The host $thisBox is down!\"" host=10.0.1.2 \
interval=30m timeout=5s up-script=":local thisBox [/system identity get name];/tool e-mail send to=tony@xxx.co\
m subject=\"Host $thisBox up!\" body=\"The host $thisBox is up!\""
Edit the order so it sends what you expect.
I tried the script, but it is giving me an expected end of line error and a few other errors. Maybe the syntax is incorrect? I’m so new to this, I’m not sure. If anyone can shed any light on this I would appreciate it. I bet it’s something really simple. Thanks.
Add this script.
/system script
add name=NetUp
edit NetUp source
/tool e-mail send to=me@mydomain.com subject="$thisBox up" body="$thisBox up"
Add this script.
/system script
add name=NetDown
edit NetDown source
/tool e-mail send to=me@mydomain.com subject="$thisBox down" body="$thisBox down"
Add this to /tool netwatch.
/tool netwatch
add host=1.2.3.4 interval=30m timeout=5s up-script=NetUp down-script=NetDown
It worked for me.
Thanks.
What I would like to do is monitor several ip devices, and add the router name in the email subject for all ip devices. I would like to accomplish this in as few steps as possible. Right now I would have to do your suggestion every time.
Is there a way to do it only once? Maybe store the variable and use it over and over?
I tried, but did not succeed. I could not find a way to set a global variable in “/tool netwatch”.
I figured it out with some trial and error. Here is what I found works:
/tool netwatch
add comment=device-ip-monitor disabled=yes down-script=“/tool e-mail send to=to
ny@xxx.com subject=([/system identity get name] . " Device Down")
" host=10.0.1.3 interval=30m timeout=1s up-script=”/tool e-mail send to=to
ny@xxx.com subject=([/system identity get name] . " Device Up")"
