Router Internet Access via BGP
I have a strange case and I can’t find a solution.
I have 2 interfaces: SFP-ISP1 and SFP-ISP2, each interface has one BGP session through a private IP.
I have a Bridge: LAN-Bridge, in this Bridge is allocated the public ip class 81.x.x.x/24 , announced through BGP
The gateway in LAN-Bridge is assigned the IP 81.x.x.1.
LAN-Bridge users can use the Internet and public IPs without any problems, but Gateway 81.x.x.1 does not, I mean the router has no internet access for itself.
(I mention that SFP-ISP1 and SFP-ISP2 are stand-alone interfaces, not part of the LAN-Bridge)
How could I make this work?
Thank you!
I solved it, who would say that sometimes ChatGPT is not a brilliant service :slight_smile:
Solution:
/routing filter rule
add chain=bgp-IN disabled=no rule=\
"if(dst in 0.0.0.0/0){set pref-src 81.x.x.1; accept;}"
Hello, I have config same to you but I am able to connect to IP .1, not need user this: /routing filter rule
“if(dst in 0.0.0.0/0){set pref-src 81.x.x.1; accept;}”
Could you please show full rsc file ?
