Router is dead
Hey I’m sorry for being complete noob, but i have a problem with RouterBoard 750GL
I accidentally clicked “D” letter in web configuration and I believe it was on Interface section and suddenly everything went offline.
Now I cant even connect to the router via ethernet cable. There is simply no connection, when I try to connect to 192.168.88.1, nothing happens, I dont even get any IP address from the router. Please help me someone how can I get to the router settings again and change what i did wrong without reseting the device to defaults, because then i wont be able to set it up as it was.
Thanks for any answer
Don’t you see the router in the neighbours of WinBox ? Did you try all the ports ?
I tried winbox also, but i cant see the router. Only sometimes some MAC address shows up, which looks like it could be the router, but no succesful connection. I really dont know what to do and how is it possible
D means “disable this item”.
When you click that in the interface section on the device that you are connected to, you are locked out.
You may be able to connect back in via another port and enable the interface again.
When not, you will have to reset the router to defaults and configure it from scratch.
