Router Issues
Hello everyone
So I have problems with my router
It’s model is RB951Ui-2HnD
So basically the Wi-Fi is working just fine, but the I have problems with Ethernet.
I tried disabling Wi-Fi, disabling then re-enabling the Ethernet adapter, re-installing the drivers but nothing worked
Then I decided to go to my router and move my cable to another port and I noticed that even then, only the Wi-Fi and Port 1 LED lights turned on
So I figured that my router doesn’t detect ports 2-5?
Maybe I’m wrong, also excuse me for my poor knowledge of routers and network terminology…
Hey
Do you have access to it’s management functionality? If you do, run “/export hide-sensitive” and paste it here between < code > code goes here </ code > tags.
