Router loses pc for 10 - 20 seconds
Hello.
hAp lite (smips)
os 6.47.9
Router network 192.168.0.0/24
Router ip 192.168.0.1
Situation one
PC with ip 192.168.0.250 (static dhcp) (eth2 interface)
in hAp terminal ping 192.168.0.250 is good. I’m link down and link up on pc and ping timeout 10-20 seconds while on another pc with ip 192.168.0.251 (from eth3 interface) ping address 192.168.0.250 is ok immediately after link up (dhcp ip receive immediately). In this regard, the Internet starts working after 10-20 seconds. On other PCs the situation is the same.
Situation two
in hAp terminal ping 192.168.0.250 is good. I’m connect to pptp server on pc without default gateway and ping timeout 10-20 seconds while on another pc with ip 192.168.0.251 (from eth3 interface) ping address 192.168.0.250 is ok and not timeout. In this regard, the Internet and vpn traffic starts working after 10-20 seconds. On other PCs the situation is the same.
I have some program which work from pptp connection and they connect to server, receive data and disconnect from server. After successful connect to server connection lost on 10-20 secs and program gives an error (timeout).
I’m create pptp connection on router as a temporary solution.
Router on default settings (only network change)
How to fix this?
