Router MikroTik RB951G-2HnD. Suddenly it stopped working.
Good afternoon.
There was a strange problem with the router MikroTik RB951G-2HnD.
Worked and at some point just stopped giving out the connection.
Out of the external signs, the WiFi light bulb stopped working.
In this case, the lamps of the connected wires flash, as expected.
The reboot did not help.
I can not connect to the router through a browser or WinBox.
It’s not clear what address the router has.
ping 192.168.88.1 gives next result
C:>ping 192.168.88.1
Pinging 192.168.88.1 with 32 bytes of data:
PING: transmit failed. General failure.
Ping statistics for 192.168.88.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
When connecting the router to the computer through the wire, the network settings information is given as follows.
Trying to do the Reset it according to the instructions: Pressed reset, turned on the router, release Reset - does not give results.
When restarting the router, it should squeak after a while, informing that it is loaded, but there are no squeaks.
Can you advise what to do?
