Hello.
Please suggest working scripts for collecting snmp metrics in munin monitoring for hap ax3.
Hello.
The search field is your friend:
Even google can help (will wonders ever cease?)
https://gallery.munin-monitoring.org/plugins/munin-contrib/snmp__mikrotik/
I found this script snmp in Perl.
doesn't work.
I enabled SNMP on the router.
The firewall allows connection for the IP address.
> /snmp/ print
enabled: yes
contact:
engine-id-suffix:
engine-id: 20234q8k
src-address: ::
trap-target:
trap-community: ExMzI24dYDEwZ8DJmYThiMWfOT3MjUwOhGNjdkk7c
trap-version: 2
trap-generators: temp-exception
vrf: main
error.
root@newy:/usr/local/etc/munin/plugins # perl snmp_ram_mikrotik
Croaking: Unable to resolve the UDP/IPv4 address "ram" at snmp_ram_mikrotik line 82.
line 82
die "Croaking: $error" unless (defined ($session));
It says that it tries to connect to a host called "ram" but it can't resolve it.
What is in snmp_ram_mikrotik?
Try
host=<ip of your mikrotik> perl snmp_ram_mikrotik
The perl code is fairly explicit and easy to understand.
My IP address is listed.
Paste here what you have on the linux host when you put the command i wrote.
