router not access
I am having rb411ah router by mistake I click on disable button on eth1 so now it is not accessing. so now I am not able to access it and my laptop or desktop lan card also not getting up. so I have access it by using serial port and reset it but now problem is that my laptop and desktop lan card getting up but I am not getting ping and it is not detect in mikrotik winbox also so please give me a any suggestion for that and give me a suggestion how to enable eth1…by command..
You can do netinstall via serial port
as it saves that you disabled the interface resetting doesn’t bring the interface up again.
use serial port:
/interface enable interfacename
