router not broadcasting wifi
Router not showing wlan network on the WIRELESS tab after rebooting, kindly assist
What router are you using ?
You need to give us more information.
check WiFi tab…
My guess from seeing the MAC address, cAP AX or AX2 (devices I have are using more or less the same range but that could be a pure coincidence).
So yes, check Wifi tab (and why is wireless loaded then ?)
Definitely so.
AX devices cannot run legacy WLAN driver, menu is called “Wireless”, it is still there for that CAPsMAN-manager.
Loaded WLAN (Wireless) software is version dependend. Still part of the RouterOS package in 7.12
MikroTik RB-RB-L41G-2axD hAP ax lite
MikroTik RB-RB-L41G-2axD hAP ax Lite
there’s nothing on the Master Interface even when i click on the drop down
OK, time to stop playing around.
Go to terminal:
/export file=anynameyouwish
Move file to computer (drag 'n drop)
Edit file, remove sensitive info (serial number, any public Wan IP)
Post contents of file between code quotes (the button with </>) for easier readability.
PS and PLEASE stop responding inside quotes. You are making it very hard for anyone to follow what you respond to what.
On the hAP ax lite, the wifi devices are under “WiFi” section.
Wireless should not be there, indeed, unless you want to use CAPsMAN v1 (and I imagine that you need the wireless package).
I would suggest to show us the content of System > Packages. Or the output of:
/system/package/print
Ur Killen me!!!
Where were you when I said MT should have an initial posting process LOL…
Do’n’t know whether to laugh or cry, but seeing you all flail around like chickens with your heads cutoff can be rather amusing…
@OP did you check WiFi menu ??
Wasn’t it @anav who said that? :wink:
