Recently i bought an MAP2nd router.
Since it was my first time with a mikrotik i made some mistakes with the config and ended up with multiple factory resets however since yesterday the router doesn’t reteurn to factory reset.
What is did was an reset config > no defaults > load the “export verbose” script from earlyer that day.
after 5 minutes the device was not reteurned to its previouse state.
power off
pres and hold the button
restore (usb) power until the USR led starts flashing
release the button and wait for another minute
this was always working but now it didn’t
i tried multiple time also with other reset lengths
found somewhere the 30,30,30 reset. where you need to hold it for 30 seconds / power off 30 secondends / power on 30 seconds release the button.
also the netinstall isn’t working
set pc ip to192.168.88.254/24
start netinstall
select net boot and set ip to 192.168.88.3
direct connect the router to the pc with a known working cabel (also tried another)
is there anything else i can do or is it simply bad luck?
The netinstall is a bootp server and will assign range you configure. I have been using range 192.168.1.2 in bootp client config on netinstall for years and no issues
There are other things you need to look at when using netinstall, i.e. check the network connection profile, should be private and not public, etc
Thanks for your reply.
i finaly found some time for testing and found the first part of the problem.
On my computer was WSL installed wich create Hyper-V network interfaces. Disable wasn’t enough. i needed to uninstall.
After this (And a reboot) the netinstall showed a device.
At packages i selected the most recent package, selected “apply default config”
When click on install the status shows install for a split second. after this the status keeps empty for 2 seconds and returned to ready.
As you can expect the router still isn’t working.
what is the change that we get this up and running? or should i return it to the shop?
The problem is on your side, not the Mikrotik device
Since the device pops up in netinstall, firewall, etc is ok and network connection profile also.
copy the .npk file into same folder as netinstall.exe
Make sure you laptop/pc doing netinstall from is in same IP range as per boot IP address in netinstall, i.e. set pc to 192.168.0.1 with subnet mask of 255.255.255.0
Start netinstall.exe with “Run as Administrator”
then in net booting config in netinstall, enable boot server and set 192.168.0.2
do the press reset button process to get the device to show in netinstall
click on device and select the package in correct folder, i.e. the one in same folder as netinstall.exe
Found something strange. the router was requesting an ip on the Eth2 . via this ip i found a page telling me the device was managed bij capsman.
here there was an option to factory reset.
This didn’t explain why all other reset methodes didn’t work.
How did i get it to “capsman” mode. and does this prevent any form of factory reset?
Reset button has various functions depending how long you press it during reset process.
Something like 5 seconds for factory reset, 10 seconds for metinstall and 15 seconds for capsman, can’t remember the details but all described in wiki article
