Router on a stick and two gateways. Is that possible?
I’ve got a DSL router from my ISP (192.168.1.1/24) that has WiFi. I have a MikroTik hEX (WAN is 192.168.1.2/24) as well. Thing is, I want to use WiFi (ISP router) and Accounting (MikroTik)
My rough idea is: a WiFi connected device (let’s say a laptop 192.168.1.3/24) will have its gateway configured to 192.168.1.2. So packets from a device will go to the ISP router, then by cable to MikroTik, then back again to the ISP router and DSL line.
Can it be done? I’ve tried with the following configuration, but no luck. MikroTik is not sending the packets back to the ISP router.
# oct/07/2021 12:09:04 by RouterOS 6.48.4
# model = RB750Gr3
add admin-mac=2C:C8:1B:60:B8:34 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=10.0.0.9-10.0.0.254
add address-pool=default-dhcp disabled=no interface=bridge name=dhcp-server
/ip accounting
set enabled=yes
/ip accounting web-access
set accessible-via-web=yes address=10.0.0.0/24
add address=10.0.0.1/24 comment=defconf interface=bridge network=10.0.0.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=10.0.0.0/24 comment=defconf gateway=10.0.0.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
  1. The firewall rules on the Mikrotik seems to be as per default, so firewall probably dropping the packet coming in on WAN interface .
  2. Have not tested your scenario, but suspect if you resolve point 1 above, the Mikrotik is going to send an icmp redirect packet back to the laptop telling it to use 192.168.1.1 as gateway anyway
