i would like to ask an simple question, which cheapest Mikrotik device would handle inter-VLAN routing (hence serves as RoS) on Cisco switch or basically any switch? This is just for lab purposes, im pretty sure considering Mikrotik price tag even VM would handle this, Im looking for least pricey solution.
Cheapest wold probably be hap lite, but with only 16 Mb of storage (and 32 Mb RAM) you won’t be able to run Ros 7 on it (or at least it won’t be easy or working “right”).
Nowadays I wouldn’t buy (new) a device with less than 64 Mb or 128 Mb storage.
Cheapest is a CHR in a virtual machine. They have a free trial. And you can also use bigger tools like GNS3 to emulate multiple routers.
If you want hardware, all the routes have same features including BGP/OSPF and certainly VLANs, so even a hAPaxLite or new “refresh” hEX both let you test things & being ARM-based will offer the full set of features (BTH, ZeroTier, Container). But if your looking to test peformance, then yeah the CPU matters, and some of the higher end routers do have L3HW offloading switch chips too… So while routing config is same on all models, not all hardware will have exactly the same config for max performance when switching since there are things to enable L3HW/etc if that’s supported.
The RB5009 is a good jack-of-all-trades with a decent CPU, so as a lab device, it’s pretty good and you can always redeploy it to production. Just not the cheapest if you’re just looking to “play” with config in hardware.
thank you so much for all replies, mine goal is to have physical lab, i used GNS3 only with Cisco images but there is no issue deploying ROS withing emulated env. so i aimed for physical device, ill sort it out now and DMOR.
