Router on stick with 2 trunks
I have a Mikrotik 5009 and a 28-port managed switch (TP-Link TL-SG1428PE). I’m trying to setup the router on a stick configuration, but instead of one trunk I’d like to setup 2 trunks, one for each of my 2 vlans (VLAN10 and VLAN20).
My goal is to have the following vlans for the ports on the switch:
Ports 1-13 → VLAN10
Ports 14-24 → VLAN20
Port 25 → ether2 (trunk for VLAN10)
Port 26 → ether3 (trunk for VLAN20)
On the switch, I have the following configured:
VLAN 1: Ports 25-28 untagged
VLAN 10: Port 25 tagged, Ports 1-13 untagged
VLAN 20: Port 26 tagged, Ports 14-24 untagged
On the Mikrotik, I setup the following to the default config:
Bridge → VLAN → Added bridge, VLAN 10, tagged ether2
Bridge → VLAN → Added bridge, VLAN 20, tagged ether3
Interfaces → + VLAN: Name: IPCams, VLAN ID 10, Interface = bridge
Interfaces → + VLAN: Name: SwDevices, VLAN ID 20, Interface = bridge
IP → Addresses → +192.168.10.1, Interface = IPCams
IP → Addresses → +192.168.20.1, Interface = SwDevices
IP → DHCP Server → DHCP Setup: Interface = IPCams, Address space = 192.168.10.0/24, Gateway: 192.168.10.1
IP → DHCP Server → DHCP Setup: Interface = SwDevices, Address space = 192.168.20.0/24, Gateway: 192.168.20.1
Interface → Bridge → Enable VLAN filtering
Now, when I plug my computer into port 1-13 of the switch, I get an IP in the 192.168.10.X range.
When I plug my computer into port 14-24 of the switch, I get an IP in the 192.168.20.X range.
If I plug one computer into port 1-13 and another computer into port 14-24, only the first computer gets an IP. The second computer on port 14-24 gets booted and it stops working.
# 2025-01-02 22:31:09 by RouterOS 7.16.2
# software id = 75ZT-AGIR
# model = RB5009UG+S+
# serial number = ***
add admin-mac=*** auto-mac=no comment=defconf name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=IPC vlan-id=10
add interface=bridge name=SwDevices vlan-id=20
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool2 ranges=192.168.20.2-192.168.20.254
add address-pool=default-dhcp interface=bridge lease-time=1d name=defconf
add address-pool=dhcp_pool1 interface=IPC lease-time=1d name=dhcp1
add address-pool=dhcp_pool2 interface=SwDevices lease-time=1d name=dhcp2
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/interface bridge vlan
add bridge=bridge tagged=ether2 vlan-ids=10
add bridge=bridge tagged=ether3 vlan-ids=20
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.10.1/24 interface=IPC network=192.168.10.0
add address=192.168.20.1/24 interface=SwDevices network=192.168.20.0
/ip dhcp-client
add address=192.168.10.0/24 dns-server=192.168.0.1,192.168.0.1 gateway=192.168.10.1
add address=192.168.20.0/24 dns-server=192.168.20.1,192.168.20.1 gateway=192.168.20.1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=192.168.10.0/24 list=IPCams
add action=accept chain=input comment="defconf: accept established,related,untracked" \
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" \
    dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=\
    !LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
    established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" \
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none \
    out-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 \
    protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." \
    dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" \
    ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" \
    in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" \
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=\
    bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=\
    bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 \
    protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" \
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" \
/system clock
set time-zone-name=***
/system note
set show-at-login=no
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
Please edit your post an use proper tags for code. http://forum.mikrotik.com/t/could-anyone-audit-my-setup/180275/12
