Router os 6.41 and ikev2 vpn connection
A few weeks ago I reset my 2011 for the new 6.41 update.
Now I have added the ikev2 vpn(based on roadwarrior example) again but I can’t connect to any lan address from the vpn.
I can ping the vpn device from the lan side but nothing further.
The vpn has internet access through the vpn.
With torch the vpn device shows up on my wan connection going out but not if I select the bridge.
So I have a feeling that I need to set something up to connect the bridge with the vpn but can’t figure out what.
Is there anyone that can help me a little bit?
Is there anyone that has had the same problem or knows a solution.
And any here also had trouble with the defconf: drop all from WAN not DSTNATed that blocked all traffic through the vpn tunnel?
