Router os 7.18
After the firmware update to 7.18 in Winbox i don,t see any settings. All windows is empty.
When i connect via ssh i can print all settings.
Anyone have ideas to resolve this issue ?
You try another PC? If not, what you wait?
Device model?
Winbox version?
RouterOS version?.. You update today to 7.18 or 7.18.2?
Do one
/export show-sensitive
on SSH, save the results and netinstall the device.
Or check the results with WinBox4.
I have a hAP ac3 RBD53iG-5HacD2HnD with version: 7.18.2 (stable).
I updated to version 7.18.2 because i think maybe this update resolve issue.
Winbox 3.41 or 4.0beta18
On another PC
winbox 3.41 stoped connection on status “Downloading descriptors..”
winbox 4.0beta18 stoped on “Reading the index file…”
From android app disconnects immediately after connection
When i typed “/export show-sensitive” ssh sesion frozen. On the 5 attempt it worked and I copy command.
