Router OS and OpenVPN Client 2.3.11
i’ve been using RouterOS with OpenVPN for some time now.
With the newest OpenVPN Client (2.3.11) i can no longer login to RouterOS. With Version 2.3.10 it works without problems.
I’ve tried upgrading RouterOS to Version 6.35.2 but it does not help.
Logfiles from Clients are attached. The Router itself does not provides something usefull in the log.
Working Client:
2.3.10.txt (4.86 KB)
Non-Working Client:
2.3.11.txt (4 KB)
Best Regard
We are aware of this issue and a fix will be available soon.
Thanks for you answer.
Best Regards
I have this issue to! Downgrade from 2.3.11 to 2.3.10…
Is there an ETA for this fix? It has broken several installations for us.
Here is temporary workaround.
Is there a fix for this yet?
Yes, this issue is fixed in the latest current versions.
