ROUTER OS bridge mode
Good morning,
I have a Fortinet Firewall Router, where I configure several VLANs, with their respective DHCP server.
What I want, is from Cloud Router Switch CRS326-24G-2S+RM, put it in bridge mode, configure the VLANs enabled in the Fortinet and according to the ETH that connects, acquires the DHCP of the specific VLAN (configured in the Forti), without configuring anything additional on the Mikrotik (Like an IP for VLAN). This should work through the same cable (A single cable connected to the Forti) which means that all traffic goes out on the ETH1, taged according to which VLAN you assign to the ETH.
I have a similar system with a Cloud Smart Switch mikrotik CRS326-24G-2S+RM, and in this one as it has no configuration mode I have been able to do it by assigning the automatic VLANS tagueo via web. In this case, being a router switch I can not do it in the same way.
