Router OS CHR x86 VLAN Configuration
As we all know, using a bridge and doing VLAN-filtering is the only way to leverage L3HW offload capabilities on Mikrotik devices that support it. I’m curious, in the situation where you are using CHR, you don’t have any built in switch chip and everything is CPU anyway, is there any benefit (performance, security or otherwise) of setting up a bridge and doing the VLAN-filtering approach? In this case wouldn’t the extermely basic and straight forward method of attaching a vlan to the parent interface directly work equally as well since there is no offload capability? See the examples below, they are not exactly the same but you get the idea.
Basic Example:
/interface vlan
add name=VLAN2 vlan-id=2 interface=ether1 disabled=no
add name=VLAN3 vlan-id=3 interface=ether1 disabled=no
add name=VLAN4 vlan-id=4 interface=ether1 disabled=no
add address=10.10.20.1/24 interface=VLAN2
add address=10.10.30.1/24 interface=VLAN3
add address=10.10.40.1/24 interface=VLAN4
Bridge Example:
add name=bridge1 frame-types=admit-only-vlan-tagged
add bridge=bridge1 interface=ether1 frame-types=admit-only-vlan-tagged
add bridge=bridge1 interface=ether2 pvid=20 frame-types=admit-only-untagged-and-priority-tagged
add bridge=bridge1 interface=ether3 pvid=30 frame-types=admit-only-untagged-and-priority-tagged
/interface bridge vlan
add bridge=bridge1 tagged=ether1 vlan-ids=20
add bridge=bridge1 tagged=ether1 vlan-ids=30
add bridge=bridge1 tagged=ether1,bridge1 vlan-ids=99
/interface vlan add
interface=bridge1 vlan-id=99 name=MGMT
add address=192.168.99.1/24 interface=MGMT
set bridge1 vlan-filtering=yes
If each of the VLAN is only needed on one single port, then the "Basic Example" way is fine for CHR/x86, and probably has less overhead, and you don't need any bridges.
However, once any of the VLANs need to span across multiple ports (such as VLAN 20 and 30 in your "Bridge Example), then Bridge VLAN Filtering is the recommended way. Because the other alternatives (VLAN in a bridge with a physical interface, Bridged VLAN on physical interfaces, Bridged VLAN, etc...) are Layer-2 misconfigurations with many issues, as documented by MikroTik on the page linked.
Ahhhh I forgot about that. You are 100% correct. Thanks for helping me remember what the other reason was behind the Bridge VLAN Filtering approach.
I had the opposite question, why would anyone NOT want to use the thing of beauty bridge vlan filtering :stuck_out_tongue_winking_eye:
