Router OS support Nforce Chipset?
Hi, I’m using MSI K9n neo V3. But When I install router os 5.22 from a cd. It show Fatal Error. No Harddisk Found and I found out k9n mobo is nvidia Chipset nforce 560 . I’ve tried many times… but unable to install. Is the router os not support nforce 560 chipset. Anyone success installed using the same chipset please share. Thanks
What disk do you have installed and which mode is it set to in the bios?
ide mode… not ahci or raid. Now the problem solve by replace an intel mobo. I guess it won’t support amd nforce 560 chipset. But if i wanna add NIC Dlink DL10038E.
I can’t see the hardware being install in the routerOS. Is it not support the above D-link Model NIC? Thanks
minor issues, like bogus/broken MSI.
otherwise anything working, contrary to intel[for example, both HPTE and APIC working].
