Hello
I copied the routeros 7.1.1 stable file to rb750r2 hex lite and it was upgraded to 7.1.1 version but there is only one package ( routeros) in the list after reboot. The other packages like hotspot, wireless and mpls are removed from the list og packages.
The extra package has some limited number of packages
How can i disable some packages like hotspot?
You can’t.
What is the reason?
MikroTik decided to combine packages into one. It makes sense for some, because of dependecies. Not necessarily for all, I think that some could have stayed separate, but they included them.
