Hi Normis,
I have same problem that was written here: http://forum.mikrotik.com/t/3-19/25882/6
In terminal in winbox when I used some command ( /ip addres print ) nothing has shown.
But it happend randomly and very rarely…
(20 minutes later)
I think I have found when it happend.
When I connect to neighbor RB via MACtelnet → I have theese problems.
Another problem that I have is Communication speed on EtherX.
I set 100Mbps in WINBOX (or by command line in Terminal)
In terminal I see that communication speed is set to 100Mbps.
3 R ;;; Port 5
name="ether5" mtu=1500 mac-address=00:03:2D:08:45:D9 arp=enabled
disable-running-check=yes auto-negotiation=yes full-duplex=yes
cable-settings=default speed=100Mbps
But in Winbox in status I see 1Gbps connection speed. And on RB led indicate 1Gbps connection speed.
Some issue there?
