I have two hAP devices and I would like to use them in manner described by attached diagram.
I my Mikrotik 1 is set as dual AP by quickset and works ok as intended, I was using some cheap router with ok result, but it has only 100Mbit LAN ports so I want to upgrade connectivity at remote network extension to 1Gbit ports.
I almost got there by setting Mikrotik 2 as CPE, set source of address WLAN and disable NAT/DHCP, but something is not all right with this setup every hour or so I get disconnected from network at Mikrotik2 side of the network an it take a minute to restore (I see disconnect and reconnect via Winbox on Mikrotik2).
Using Mikrotik 1 set by quickset to PTP Bridge AP mess up lot of my previously working settings so I guess editing my Dual AP settings to use WLAN2 as dedicated interface to link between two devices and set Mikrotik 2 properly (just connect over 5GHz and forward DHCP and transparent connection to LAN ports) is the most reasonable way, but I am not skilled enough.
Can somebody please help me?
