Hello All. how are you doing?
I a newbie with Mikrotik stuff and I need to implement a switch and a DHCP server. As I got a Router RB2011 to start with this Mikrotik world, I’m going to use it.
I have to use 3 port as a switch, but really it can be a hub because I’m not going to implement any VLAN in the network. The ports I thought to use eth1 , eth3 and eth4. that where the host will be connected. So I choose eth2 as a master port.
Something like this
The configuration is this:
jan/02/1970 00:36:02 by RouterOS 6.37.4
# software id = 818B-XRQ1
set [ find default-name=ether3 ] master-port=ether2
set [ find default-name=ether4 ] master-port=ether2
set [ find default-name=ether1 ] master-port=ether2
add name=dhcp_pool1 ranges=192.168.100.2-192.168.100.254
add name=dhcp_pool2 ranges=192.168.100.2-192.168.100.254
add address-pool=dhcp_pool2 disabled=no interface=ether2 name=dhcp1 relay=\
192.168.100.1
add address=192.168.100.1/24 interface=ether2 network=192.168.100.0
add address=192.168.100.0/24 dns-server=0.0.0.0 gateway=192.168.100.1
But that is not running. What I’m doing bad?
Thanks and best regards.
