Router RB2011 impossible to upgrade to 6.42.5
Hi Guys.
I need to upgrade the Software version to 6.42.5 to avoid the last bug in the 6.3 version.
I try using winbox, using the automatic upgrade option and also from console with “system/router/upgrade”.
After download the package successfull , I reload and continues with the same version. The Log shows " software downloaded successfully, reload the router"
Also i have the same problem with the firmware that actually has the V3.33. I can’t update it from winbox. It shows the message “firmware upgraded, reload router”, but after reload it continues with the same version.
I check other articles but nothing i continue with the problem
Any help is welcome.
David
System > Packages > Update to latest Current.
-then-
System > Routerboard > Upgrade
I had a similar issue yesterday. I had to use netinstall to get it upgraded.
