Hello everybody!
I have problem with port 22 on this router. I try to connect with ssh from LAN to outer IP on port 22 - doesn’t connect, only ‘Connected time out’, I try connect with ssh on port 22 from LAN to router console, this same doesn’t connect. But if I change ssh service port to 2222, I can connect to router console. Connect with telnet to router (port 23) is work.
If I connecting from public IP to IP in LAN on port 22, 3307 etc. I can connect.
Only if I try connect from LAN to outer IP on 22 port I can’t.
That is typically behavior for this router?
router upgraded to 6.39 latest routeros
J.
