Hello
Hello
I have a mikrotik router reference RB3011 and two WiFi APs reference cAP ax, I need through the main RouterOS using the CAPSMAN functionality to be able to configure the two interfaces, so that from there they both broadcast two different WiFi networks, I understand that this is only supported from version 7.7 (beta) of RouterOS, but only through the CLI and I am not clear how to do the process (manual and logical configuration), both configuration in the cAP aX, and in the CLI console of the main RouterOS
I would appreciate if you could tell me the steps to do it, since I previously had it that way using other old cAPs and in both I could broadcast two LAN networks through different SSIDs on both devices at the same time (mesh).
https://mikrotik.com/product/RB3011UiAS-RM
https://mikrotik.com/product/cap_ax
Thank you!
